Finite Element Analysis (FEA) | Contact Analysis
How to Address Contact Problems in Finite Element Analysis (FEA)
In finite element analysis, addressing contact problems is a critical step as contact behavior significantly affects stress distribution and overall structural performance. Contact problems often involve nonlinear behavior, requiring specialized algorithms for resolution. Below is an outline of the general methods and steps used in FEA to handle contact problems:
Defining Contact Pairs and Types
  • Contact Pairs: Define pairs of surfaces or bodies that are in contact or might come into contact.
  • Contact Types: Include welded contact, rough contact, adhesive contact, and sliding contact.
Detecting Contact Points
  1. Node-to-Surface Contact Search
    • Checks whether subordinate nodes penetrate the master surface.
  2. Surface-to-Surface Contact Search
    • Identifies non-penetration conditions between subordinate and master surfaces.
Calculating Contact Forces and Tangential Stiffness
  1. Penalty Method
    • Converts contact conditions into soft constraints by introducing a penalty factor on the contact surface. Contact force is calculated as:
      \text{Contact Force} = \text{Penalty Factor} \times \text{Gap Size}
  2. Lagrange Multiplier Method
    • Satisfies contact conditions directly by introducing Lagrange multipliers, ensuring zero relative displacement on the contact surface. Contact force is given by:
      \text{Contact Force} = \text{Lagrange Multiplier} \times \text{Normal Vector of the Contact Surface}
Applications of Contact Problems
Solutions for contact problems are widely used in various engineering fields, such as:
  • Mechanical Engineering: Bearings, gears, support structures.
  • Materials Engineering: Contact behavior and interface friction of different materials.
  • Automotive Engineering: Tire-road contact, brake pad and disc performance.
  • Geotechnical Engineering: Interaction between soil and structures.
Common Penalty Methods
1. Penalty Method
  • A widely used algorithm in contact problems.
  • Converts contact conditions into soft constraints via a penalty factor.
  • Effective for all types of nonlinear contact, including frictional and frictionless contact.
2. Augmented Lagrange Method
  • An improvement over the penalty method, introducing an additional term ( \lambda ) to reduce sensitivity to contact stiffness.
  • Enhances convergence and computational accuracy, especially for cases with high contact stiffness.
3. Multi-Point Constraint Method (MPC)
  • Suitable for bonded or non-separable contact.
  • Adds constraint equations between contact surfaces to directly link displacements, avoiding penetration.
  • Particularly useful for large deformation analysis.
Comparison of Penalty Method, Augmented Lagrange Method, and MPC
Method Advantages Disadvantages
Penalty Method Short computation time, low cost Lower accuracy, potential oscillation
Augmented Lagrange Better convergence for high stiffness Slightly higher computational cost
MPC Avoids penetration, suitable for large deformation Requires careful constraint definition
Advantages and Limitations of the Penalty Contact Algorithm
Advantages
  1. High Computational Efficiency
    • Simplifies the process by using penalty factors to convert contact conditions into soft constraints, eliminating the need for complex iterations.
  2. Momentum Conservation
    • Maintains momentum conservation as contact forces are directly calculated based on the penalty factor and penetration.
  3. Versatility
    • Applicable to all types of nonlinear contact, including frictional and frictionless scenarios.
Limitations
  1. Accuracy Depends on Contact Stiffness and Penetration
    • Precision is influenced by the magnitude of contact stiffness and penetration, as penalty methods use numerical approximations to enhance convergence.
  2. Convergence Challenges
    • Allows slight penetration, which may lead to oscillation between penetration and non-penetration, affecting convergence.
Conclusion
While the penalty method is efficient and versatile for handling contact problems in FEA, its limitations in accuracy and convergence require careful consideration. Selecting the appropriate contact algorithm depends on the specific characteristics and requirements of the problem.
Thanks, marked.
