MechBox — Online Design and Tolerance Analysis Tool
MechBox is an online tool platform built for mechanical design, process, and quality engineers. It brings together commonly used engineering calculation features such as tolerance stack-up, tolerance analysis, GD&T verification, statistics and Monte Carlo analysis, fit and interference calculations, thermal expansion, and fatigue life estimation. The platform uses a clear, consistent input interface and traceable export reports. It supports saving projects, bulk parameter import, and exporting results to PDF/Excel, making it easier for engineers to quickly validate solutions and generate auditable calculation records during design reviews and manufacturing delivery.
Key highlights:
  • One-stop coverage of common engineering modules: tolerance stacks, RSS/worst-case analysis, GD&T, tolerance allocation, bearing life, bolt preload, thermal expansion coefficients, fatigue estimation, and more.
  • Engineering-grade output: formula sources, input assumptions, units, results, and export reports are all traceable, making review and archiving easier.
  • Reusable projects and batch calculations: supports project saving, version history, CSV bulk import, and solution comparison.
  • Integrated statistics and uncertainty assessment: supports normal/uniform/triangular distribution modeling, Monte Carlo simulation, and Cpk/yield calculations.
  • Easy to use yet rigorous: the interface is suitable for quick trial calculations, while also reminding users of applicability conditions and safety considerations at every key calculation point.
Intended users:
  • Structural design engineers and component design engineers
  • Process engineers and assembly engineers
  • Quality engineering and reliability engineers
  • Mechanical engineering students and engineering interns
Try it here: MechBox Mechanical Toolbox
Works great, thumbs up! :+1:
Pretty good, thanks.
