Originally published at: 响应面法协同优化3D打印氧化铝多孔陶瓷的气孔率和抗弯强度 – RSS News
摘要:氧化铝多孔陶瓷在过滤领域具有广泛应用,其气孔率和抗弯强度通常呈负相关性,而高效过滤材料需兼具高气孔率与高强度。采用浆料挤出3D打印技术,以填充率、打印层高和打印速度三个关键工艺参数进行响应面试验,分析打印参数间交互作用对氧化铝多孔陶瓷气孔率和抗弯强度的影响,并建立二阶非线性数学关联方程。结果表明,填充率与其他工艺参数的交互作用对气孔率和抗弯强度影响最显著,其次为打印速度和打印层高。当挤出头内径为0.41 mm、填充率为50%、层高为挤出头内径的67%、打印速度为1 100 mm/min时,氧化铝多孔陶瓷的气孔率为69.28%,抗弯强度为9.04 MPa,在X、Y和Z方向的收缩率分别为3.86%、4.21%、5.63%,侧面粗糙度为18.16 μm。研究结果可为优化3D打印多孔陶瓷的成形工艺提供理论依据,并为高气孔率、高强度过滤陶瓷的设计与制备提供参考。
Abstract:Alumina porous ceramics have widespread applications in the filtration field, while its porosity and flexural strength typically exhibit a negative correlation. However, efficient filtration materials require a combination of high porosity and high strength. Alumina porous ceramics is fabricated by slurry extrusion 3D printing technology, based on response surface methodology, filling rate, layer height, and printing speed are analyzed as independent variables to assess their effects on the porosity and flexural strength of the sintered alumina ceramics. The interaction effects among process parameters are analyzed, and a second-order nonlinear correlation mathematical equation are established. The results indicate that the interaction between filling rate and other process parameters have the most significant effect on porosity and flexural strength, followed by printing speed and layer height. The optimal process parameters for synergistic optimization of porosity and flexural strength are obtained, presenting a nozzle diameter of 0.41 mm, a filling rate of 50%, a layer height of 67% of the nozzle diameter, and a printing speed of 1 100 mm/min, the corresponding alumina porous ceramics achieved a porosity of 69.28%, a flexural strength of 9.04 MPa, with shrinkage rates of 3.86%, 4.21%, and 5.63% in the X, Y, and Z directions, respectively, and a side surface roughness of 18.16 μm. These findings provide a theoretical basis for optimizing the 3D printing process of porous ceramics and offer valuable insights for the design and fabrication of high-porosity, high-strength filtration ceramics.
关键词
氧化铝多孔陶瓷, 浆料挤出3D打印, 响应面试验, 抗弯强度, 气孔率
Key words
alumina porous ceramics, slurry extrusion 3D printing, response surface methodology, flexural strength, porosity
